Title says it all. I have install: cai aem and apex exhaust which is a cat back.
NGK, which is what the car comes w/ from the factory.
NGK Iridium IX is what a lot of people use, better than the stock platinums.
Nissan recommends a colder plug in their shop manual for mostly highway driving and higher than normal revving. This may help reduce engine knock at these conditions (heat range 6 instead of the standard heat range 5).
NGK offers 4 grades of plugs for the SpecV. Note that the chart lists all heat range 5 plugs. Just substitute 6A for 5A to get the colder plug.
Manufacturers don't agree on a standard heat range scale. The cross reference chart allows you to compare heat range equivalents for 5 plug producers.
wats the miles on the car?
Team N.V
Scrapin:somehow we ran into tuned_de on the highway and him and the bimmer went at it in traffic, that tuned_de mofo is nuts and so was the driver of the bimmer...lmao
^-- what does that have to do w/ this thread? majority of the boosted people have been around very very long![]()
The original question was very legitimate. Only two of the boosted people replied: "NGK" and "iridium NGK". I provided a little more information to make a correct choice (BTW, thanks for the acknowledgment).
I respect you and everybody else who has been around a long time. I was hoping to elicit some comments from this group regarding choosing a correct heat range plug for a given application. I too have been around for a long time - I was racing at Island Dragway in 1963 and in Englishtown when it first opened a few years later. I learned very early that the cheapest mod was correct tire pressure, good fuel, good clean oil and a proper spark plug.
I apologize if I offended anyone.
i got Denso iridium's if anyone is curious..
PULSTAR , pricey but worth it.
Thanks for the help guys. The NGK Iridium IX sounds like the right choice.
I have Denso Iridium
If I remember correctly I was running a hotter plug on my boosted SR20 so the spark doesn't get blown out by the boost pressure and made a difference on the Dyno, I would've showed but gave the dyno sheets when I sold the car I went from 479.6 WHP to 487.2 WHP and the car ran smoother with the hotter plugs, this was on a Pulsar GTi-R Swap with a precision SC61 top mounted, ebay inter-cooler, ITBs, and some other goodies 8.3:1 comp.
just wanted to chime in to say PLUGS MAKE A BIG DIFFERENCE
The purpose of a hotter plug is to keep the plug from fouling at low RPM and in stop-and-go driving. In high-revving, high compression and boosted applications the hotter plug will sometimes result in knock because the heat of the plug will fire the combustion chamber before the spark does. If this happens often enough, you will generate a 0300 code - misfire.
I use the laser-platinum heat range 6 plug for my normal driving and will probably go to an iridium heat range 7 plug once I start racing.
No arguement there you're right, I did do a lot of driving in NYC when I had my old 91 SE-R so that's why but even at higher revs it felt smoother when I put in the hotter plug, as for my Spec-V I'm getting my 6 heat range plugs from my Job OEM Nissan, just cuz it's cheaper for me that way
never mind........... LOLS
who stole your sig?
Custom SRI/XS Header/XS Flexpipe/XS Midpipe/GReddy Sp2 Catback/Energy Suspension MMI/K Sport Coilovers/Nismo Short Throw Shifter/8000K Hi-Low HIDs
For the NGK IX Iridium, what p/n? There are numerous on the Advance Auto website. Maybe some of them are colder than others, not sure. If not I was going with what shows up as "replacement" for this engine
