Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21
    u jelly ? gurov is offline
    Feb 2009
    Show me some timing stuff.
    is there injector timing under FUEL ?
    2004 BMW 325XI AWD Turbo Auto - standalone engine and trans controller - SLC_OEM - 62mm turbo
    1994 Toyota Supra Twin Turbo - AEM V2 - in the mail bugatti veyron pump, 1000cc ID, T72
    2004 Nissan SE-R SpecV Turbo - standalone, j&s safeguard, modified stock injectors. (gone)
  2. #22
    Germany
    there is a latency value........... but the cable acts like a dongle, and it's with the race car, so I can't access the program ATM.
  3. #23
    Feb 2009
    Quote Originally Posted by Big J View Post
    there's that... it says min effective inj PW is 2.45ms, that doesn't seem right at all... confirm ?
  4. #24
    Germany
    2.46 ms is the minimum time the injector can be commanded open and it'll actually open........ like resolution??
    Those pics are from an OLD version of the program....... the new version has a latency tool to calculate "lag" time vs system voltage and it doesn't leave it in HEX
  5. #25
    Feb 2009
    any new shots anybody can provide ? 2.46ms seems WAAAAY too high for opening time for an injector.
    it's certainly not resolution, commandable injector resolution is usually in the .001ms range.
  6. #26
    Germany
    I won't be able to get the cable until Sunday
  7. #27
    Rochester, NY
    Is Uprev going to do this for '02-'03? It has been a pain in the balls with my car....Now I have 720cc injectors, running E85 and revving to 7500+. These injectors are too big on 9lbs of boost. I can turn up the boost, but I'm afraid this motor is going to detonate soon. I don't think anyone has revved the QR this high consistently. Mine just keeps taking it....but who know for how long. It's not making the power it should too, because it's so rich up top. The SAFC NEO works for now, but I'd like something better.
  8. #28
    Andy westner is online now
    Paramus, NJ
    Quote Originally Posted by Brad View Post
    Cant wait to get mine and start playing.
    Has anyone tried using launch control via map switching? I saw mention of this on the 350z forum. Just wondering if it will work for us too.
    One of the 5 maps is a "Valet" map with a 3000 rpm rev limit. You can change this rev limit to the number you want to launch at. Go into this map as you stage then change to your "race" map, but don't let go of the CC-Cancel button until you launch. Rev the car to the pre-set limit, launch at your light and let go of the button. As soon as you release the button you are in "race" mode. Voilla, a 2-step launch!
  9. #29
    Armando armandotech is offline
    Aug 2009
    Orlando,FL
    Quote Originally Posted by xxchuncexx View Post
    As far as I know 02-03's are not supported and won't be for a good amount of time if ever, the only choice you have is to go stand alone
  10. #30
    Feb 2009
    any cranking pulsewidth maps VS temperature ?
  11. #31
    Germany
    Quote Originally Posted by gurov View Post
    there is a cold start enrichment that is a % of base...... so when it's cold, like 150% of base......... which is why on a car w/ big injectors and no cold start correction, it will stumble for 2-3 seconds.
  12. #32
    Feb 2009
    naturally.
    can you please post a screenshot of this along with any other temperature-related correction tables there are ?
  13. #33
    Aug 2009
    Southern, MD
    do you have to hooked up to the ecu to look at the files. i have my rom file. havent flashed the ecu yet. but i like to just look at the program. dosent look like i can!?!!?
  14. #34
    Paramus, NJ
    Quote Originally Posted by sweetspecv View Post
    You don't need to be hooked up to the ECU to read or edit the ROM file but you do need to connect your cable to the computer. The cable has all the license information that allows the user to use the programs he purchased.
  15. #35
    Aug 2009
    Southern, MD
    Ah cool thanks man
  1. Turbo Compressor Maps
    By ash in forum Forced Induction & Supporting Modifications
    Last Post: 10-25-2011, 08:16 AM
  2. For those who want to learn...Compressor Maps
    By executiV in forum Forced Induction & Supporting Modifications
    Last Post: 10-27-2008, 10:33 PM
  3. Are you on Google Maps?
    By illoosionz in forum Video Games & Multimedia
    Last Post: 07-07-2008, 11:13 AM
  4. Google maps now with street view
    By Teckfall in forum Open Bar
    Last Post: 05-31-2007, 10:36 AM
  5. Google Maps
    By ash in forum Open Bar
    Last Post: 04-12-2007, 06:53 PM
