Results 1 to 20 of 35
    Germany
    Default maps on factory ECU
    I'm going to post up what some of the maps look like in UpRev's Map Editor.
    Target AFR map:
    Default Re: maps on factory ECU
    Base fuel schedule?
    Germany
    base fuel schedule is basically load
    Germany
    so the X and Y axis are load and RPM
    Gotcha. More pics please
    Germany
    any requests?
    Show me some timing stuff.
    Germany
    cam timing:
    my best guess is one map is accelerating and one is off throttle.....
    Germany
    ignition timing...... not standard degrees BTDC....... calculates fuel burn time...... but, changing a value 1 numbers is about 1/2 timing.
    damn, so w/ the AFR target, you just set a # and the ECU just the rest?
    Andy westner is online now
    Paramus, NJ
    Quote Originally Posted by Big J View Post
    any requests?
    Are these screen shots of a QR or VQ maps?
    Were you able to achieve WOT? If so, please post the Electronic Throttle map.
    Paramus, NJ
    Most of the maps have a max value for RPM at 6000-6400. I'm installing springs and cams to run at 7000-7200. Do I need to extend the RPM range on the Y axis?
    Germany
    no, lol.
    There is a fuel compensation map that has to be correctly tuned for the target AFR maps to be accurate.
    ALSO, when you add larger injectors, you have to tweak the injector to MAF scaling, aka the K value, to get things in the ball park first. Then you tweak the compensation maps, before you can even worry about the target maps even being close, lol. Because you can tweak the MAF tables, you can really extend how much air flow the stock MAF can take before it maxes out.
    You can also directly tweak the MAF tables kinda like an SAFC.
    This is why I want to do a base map based on modded stock injectors..... that way noone has to buy injectors ever again, just modify the stockers and flash the base fueling map.
    Germany
    Quote Originally Posted by westner View Post
    QR.
    I haven't tried tuning that as of yet. I live in downtown Atlanta now and not the suburbs...... nowhere to really open up a 300whp car over and over.
    Germany
    You can extend the RPMs, but you're not going to gain extra load points, so you'll end up with skewed maps until you retune. I would definitely extend the maps into the RPM ranges you want to run.
    Shreveport, Lousiana
    Cant wait to get mine and start playing.
    Has anyone tried using launch control via map switching? I saw mention of this on the 350z forum. Just wondering if it will work for us too.
    2005 Spec-V with SC-61 >13.1@110
    Aug 2009
    Southern, MD
    soon ill be getting up rev and pro veriosn. going to local shop to get it tuned. and ill tweak what need later. as of now im running the stock moddifed injectors, and plan on using them. hope they work for my 450hp goal.
    ill post up map if you want. once i get it done. working on unhooking the megasquirt and getting it a booost controller.
    Aug 2009
    Southern, MD
    do you think the car will idle smooth with the modified stock injectors. i unhooked the megasquirt, and with the modified stocks the car wont start until i turned fuel pressure down to 20psi and idles like shit. wondering if the up rev you can get it smoothed out. other wise i gonna throw in something else.
    Germany
    Quote Originally Posted by sweetspecv View Post
    Haven't had time to mess with it. There shouldn't be any reason why it won't work.
    Aug 2009
    Southern, MD
    hmm, maybe ill try it. hate to tow it up there and they cant get it working with the mod stocks
  1. Turbo Compressor Maps
    By ash in forum Forced Induction & Supporting Modifications
    Last Post: 10-25-2011, 08:16 AM
  2. For those who want to learn...Compressor Maps
    By executiV in forum Forced Induction & Supporting Modifications
    Last Post: 10-27-2008, 10:33 PM
  3. Are you on Google Maps?
    By illoosionz in forum Video Games & Multimedia
    Last Post: 07-07-2008, 11:13 AM
  4. Google maps now with street view
    By Teckfall in forum Open Bar
    Last Post: 05-31-2007, 10:36 AM
  5. Google Maps
    By ash in forum Open Bar
    Last Post: 04-12-2007, 06:53 PM
