I have an 04 spec v that I'm fixing to turbo and using safc2 to tune it but I live about 50 miles from somewhere that can tune the car for me...is there any way I can tune it myself to make it driveable or am I better off having it towed?
Buy a wideband and tune it yourself. SAFC's are very easy to tune with. Otherwise you can drive the car safely to the tuner as long as you stay out of boost.
I'm not 100% sure what you mean by a wideband?![]()
A wideband o2 sensor and gauge will tell you your air/fuel ratio, which can then be adjusted via SAFC.
So I get the wideband o2 sensor and air/fuel ratio gauge and use the safc to get to a medium?
If your using 630cc I have a brand new unichip plug & play EMS f/s let me know k
CATCH ME IF U CAN
How much for the unichip?
pm sent
CATCH ME IF U CAN
sorry in advance for the thread jack. Will an air/fuel gauge work without a wideband o2 sensor? I'm reading on other boards that if you do not have a wideband then the AFR gauge will either not work or go crazy even during consistent steady driving.
You can run a A/F gauge using the normal o2 but they will be narrowband and not accurate at all. I Would not tune using a narrowband.
anyway to tell if its a stock o2 sensor or a wideband sensor by looking at them?
2004 BMW 325XI AWD Turbo Auto - standalone engine and trans controller - SLC_OEM - 62mm turbo
1994 Toyota Supra Twin Turbo - AEM V2 - in the mail bugatti veyron pump, 1000cc ID, T72
2004 Nissan SE-R SpecV Turbo - standalone, j&s safeguard, modified stock injectors. (gone)
Wideband is 5wire and narowband is 4. My HX civic came with a factory 5 wire wideband O2.
"ITS A TURBO THING................U WOULDN'T UNDERSTAND."
