Results 1 to 20 of 21
    Nov 2011
    Default ECU and Chasis grounds?
    (I have no SES light and am doing some testing, also no fuel pump)
    All the relays have power and ground.
    I uploaded the pinout for the ECU with markers.
    So I'm checking my ECU harness and this is what I find.
    The good;
    Red - pins 109 and 111 both have good 12v sources
    Black - pin 108 - Good ground, returns 12 volts
    The odd;
    Blue - pin 59 ( supposed to be a ground? ) no wire there
    The bad;
    Green - pins 60 and 106 - Supposed to be ground, return 0 volts when testing
    Would I be able to just reground these to the battery myself to solve this issue?
    Also where are the grounds located on the car, some people say they have loose grounds, so I replaced the battery ground , but where are all the other ones lol. Any input is appreciated!
    Lucas Specv03 is offline
    NH
    Slapped 2 Times in 1 Post
    Everything on the engine harness grounds on the timing cover. Take some sandpaper to the mating surfaces and see if that helps something
    Black '03 - Supercharged.................StopTheFakes
    Yellow '04 - Runs on ground unicorn horn
    Quote Originally Posted by JVSpecV View Post
    A twin charged, 6 wheel awd, center steer, sqr powered spec v with n2o is no laughing matter.
    Nov 2011
    I see 4 bolts, 2 wires to each on the top portion of the timing cover, checked all those grounds and seemed to be good. Any chance anyone knows which one goes to which pin out? I could test the OHMs of each wire, that' d be a great test.
    Jon
    Jon Jon is offline
    Jul 2011
    Tilton, NH
    Quote Originally Posted by vexixx View Post
    The good;
    The odd;
    The bad;
    Grounds should not show voltage that would be a bad thing Ground pins should show continuity to ground source "Green - pins 60 and 106 - Supposed to be ground, return 0 volts when testing"
    adam willms81 is online now
    Copperas Cove, Tx
    Slapped 3 Times in 3 Posts
    Almost sounds like your ecu could be bad. I had fuel but no spark with no ses. Turned out my ecu quit on me. Something to maybe keep in mind because a faulty ecu can show up as any number of weird problems.
    Nitrous is like a hot girl with STDs, you know you want to hit it, but you're afraid of the consequences...
    Quote Originally Posted by skwirl View Post
    That's because its impossible to be pretentious when you're driving a sentra. Being an elitist sentra owner is like thinking you're the smartest kid in the special ed class.
    Nov 2011
    Well I got another ECU from ebay because the dealership said this one was bad. However the one I just got returns the same results.
    I'm not checking the ECU itself though but the harness itself.
    Why should a ground not show 12v on the multimeter if the positive lead is on the battery?
    NH
    You went wrong with ebay. Just get one from a partout on here. In fact i have a perfectly good p5 ecu for sale
    Germany
    Don't use an ecu ground to check if it's hooked the the ecu
    Nov 2011
    ECU isn't connected, just checking the harness to make sure I'm getting all the correct inputs.
    The ECU was pulled from a wrecked car so I figured it was good , but eBay offers much more security than forum buys ( I've been ripped off on forums before ).
    Anyone happen to have a diagram where where ground wires go to, I can do a continuity test on each wire. If I know my harness is good then I know its not the ECU or its a sensor.
    Unless someone with a running 03 Spec V SE-R lives close to Paso Robles, CA that can test it ;-) (ECU is a K3)
    Jon
    Jon Jon is offline
    Jul 2011
    Tilton, NH
    You have power to fuel pump relay? do you have power out of relay?
    Cornelio CORN DOG is offline
    Mesa, AZ
    Quote Originally Posted by Specv03 View Post
    Lucas, can you PM me a price on that ECU??
    Its a 02-03 Non Nats unit correct?
    Thats what i would like to get (then send to JWT for a reflash, i have the TN reflash now)
    Jon
    Jon Jon is offline
    Jul 2011
    Tilton, NH
    You can check continuity to any chassis ground location You can download the diagram from here
    Jon
    Jon Jon is offline
    Jul 2011
    Tilton, NH
    How much did they charge for the ebay ecu?
    NH
    Quote Originally Posted by CORN DOG View Post
    For without nats your going to need either a 5L (2002) or K3 (2003) both have the same pinouts and are interchangeable, but the 5P is for 2002-2003 w/nats
    Nov 2011
    Quote Originally Posted by Jon View Post
    There is nothing on my pc after here..
    Also I did an ohm reading and as I said earlier the good ground (pin 108) came up as 0.2 all over the car. However pin 60 showed up, but as a whooping 147.2 so there's some series resistance in this line.
    The other grounds showed me no response.
    Nov 2011
    I have power to the relay I did not check after the relay.
    Jon
    Jon Jon is offline
    Jul 2011
    Tilton, NH
    Nissan Sentra Factory Service Manuals
    Download the manual here great trouble shooting info sounds like a ground make sure you are looking at the 2.5 not the 1.8 when you look at manual trouble shooting
    Jon
    Jon Jon is offline
    Jul 2011
    Tilton, NH
    The trouble shooting for that board/harness starts around section EC page EC-1326 I think....
    Nov 2011
    So after reading through this, the ECM pinout isn't the same as mine.
    I've been using this for my ECU harness info so far.
    I really need the ecu pinout for a 2003 Nissan Sentra Spec-v. - JustAnswer
    If you look at the ECU pinout diagram its completely different, is there a FSM for 2003 sentra spec-v?
    Thank you btw though.
    Nov 2011
    So in the end I got my SES light back on.... Although I'm not proud lol..
    Anyway so the tech that did the diagnosing didn't replace the ECU relay. When I went to check what I thought was the ECU relay it wasn't, was another relay. The plug for the ECU relay was put back but with nothing in it so I thought it was an unused adapter for a different model.
    Still doesn't start, but at least I finally narrowed it down to the fuel pump.
  1. VQ35DE which ecu
    By Taz in forum Engine Swaps, Builds
    Last Post: 11-26-2011, 04:21 PM
  2. Ecu
    By Dudu in forum Troubleshooting and Support
    Last Post: 08-15-2011, 05:14 AM
  3. 06 ecu same as 04?
    By tacoerick in forum Tuning & Engine Management
    Last Post: 05-18-2011, 04:44 PM
  4. Different Chasis, Same engine, Same goal
    By L31_06 in forum Introductions
    Last Post: 06-29-2010, 10:36 PM
  5. Ecu.... ?
    By Blackout_03SpecV in forum B15 Sentra (2000 - 2006)
    Last Post: 12-29-2009, 01:45 PM
