Results 1 to 10 of 10
    Jared bigjrod213 is offline
    Murfreesboro, TN
    Default Need advice on cipher results
    I've been getting into some datalogging with Cipher lately. But I've been having a problem, my car has lost power and is very sluggish through the whole powerband. The exhaust sounds like shit and theres a hesitation when I floor it, almost like it can't get fuel fast enough.
    The car has a hotshot header, tanabe catback, nismo cai and stock midpipe.
    This loss of power started when i had the rear o2 wiring extended 13 inches to go behind the main cat to avoid codes. I've been hesitant to set it back because I haven't found an o2 sim.
    Also there aren't any codes or other symptoms besides loss of power.
    Any help with interpreting or advice is greatly appreciated.
    Name:  cipher log1a.jpg
    Gary un33dit is offline
    LI NY
    Check with Scrapin. He was selling o2 Sims at one point.
    Murfreesboro, TN
    Can anyone tell me if this is normal? Thought it was strange that the voltage stays the same for so long.
    Name:  cipher log1b.jpg
    Murfreesboro, TN
    bump, any ideas?
    Ray Solis Pfbspecv is online now
    Oct 2011
    Tucson Arizona
    Quote Originally Posted by bigjrod213 View Post
    bump, any ideas?
    is your problem like this??? i had like a hiccup in my car.
    Sentra Se-R Spec V PROBLEM!!! - YouTube
    My Spec V was once stock!
    Check out my build thread.
    Darren SurraTT is offline
    Jun 2011
    Greensboro, NC
    Attachment 22287
    Yes, thats because you are WOT at that point.
    WHP=301 with stock cams :eek:
    2009 VQ engine Swap thread
    336.270.9202 CALL/TXT
    Need a Patch Harness or Plug and Play Haltech/UTEC/EMU Harness? www.VoltageDrop.net !
    Murfreesboro, TN
    Quote Originally Posted by Pfbspecv View Post
    Yea it's something pretty similar. Do you remember by chance which hose was the problem? Can't figure this out for the life of me.
    Oct 2011
    Tucson Arizona
    OK so heres what we found. the vacuum line from the intake to the block wasnt on all the way.... then later on i had the hiccup again. it turned out to be the fuel trim. You need to retune your car and start from scratch basicly. start a whole new map. this should clear up the problem. everytime i add a modd and the try tuning the tune thats already there i end up with a hiccup. my tuner would then start a new map and retune and the issue is gone.
    What are you tuning with?
    Oct 2011
    Tucson Arizona
    What am i tuning with?? If the question was to me im tuning with the aem f i/c for now.
  1. need cipher cable!
    By White_Spec-V in forum Parts Wanted
    Last Post: 10-09-2011, 07:59 PM
  2. Cipher install help!
    By SlowCarGuy in forum Tuning & Engine Management
    Last Post: 01-09-2011, 02:41 AM
  3. How To: Wire Cipher
    By SlowCarGuy in forum Sentra Specific Installation Guides & Technical Info
    Last Post: 01-09-2011, 02:24 AM
  4. My dyno results, this is B.S
    By Splash45 in forum Naturally Aspirated (NA)
    Last Post: 06-19-2008, 03:23 PM
