Results 1 to 3 of 3
    Default Oil change vs. Oil Flush
    Wats up Sentra crew!!!? I believe I need to get my oil changed but I had a couple of questions that ya can help me out with.
    1. How often do you need to get an oil change?
    2. How much do an oil change cost?
    3. What does it mean to flush out your system?
    4. which is better: a flush or an oil change?
    Thanxs in advance for the people who can help me out!
    oil change depends on how you drive your car and what kind of oil u use...
    if you are using regular non synthetic oil around ever 3000 miles
    synthetic can last up to 5000 miles
    oil change prices vary, i get mine done at the car wash for 30 bucks regular oil, top off all fluids and all that other stuff, and i get a free car wash at the end of it.
    flushing the system is draining the oil, and pouring a quart of oil or two through the motor while the oil pan plug is still removed.
    realisticly flushing might be better or it may not be its debateable... i wouldnt waste my time or the oil.
    Sebastian SpecBEE is offline
    Nov 2006
    Slapped 3 Times in 1 Post
    do like the honda kid did and pour water in your oil tank to flush it... JOKING..
    just do oil changes, you really need to flush it only if you dont change your oil every 3k.. say for example like every 20k LOL
    typical price for an oil change at autozone is 15 dollars DIY.. or 29.95 at shops, some shops have s[pecials for 19.95
    synthetic oil is more expensive,
  1. Change the headgasket on the QR25DE. (Altima Sentra)
    Last Post: 05-10-2012, 05:21 PM
  2. wheel color change for the summer
    By B15Chris in forum Member Rides and Project Cars
    Last Post: 05-26-2009, 01:34 AM
  3. how to change bulb in shifter??
    By DJ_Imran in forum Transmissions, Clutches, etc.
    Last Post: 11-07-2008, 05:58 PM
  4. best/cheapest place to change struts
    By vincent in forum B15 Sentra (2000 - 2006)
    Last Post: 09-25-2006, 11:43 AM
