So i pretty much know absolutely nothing about datalogging. So i guess my first question is, where the hell do i even start??
first...get a something that can datalog lol...
If you want to log your AFR vs. RPM you'll need a wideband setup that can log like the Zeitronix or Innovate w/ SSI-4.
and a laptop
You will also need a serial to usb adaptor and this is where i had problems, get the one from best buy, this is the one I used and it works, I tried many other ones I have around the house for phone system programming but none of them worked but the one from best buy did.
USB to Serial Adapter - P/N: 3733 - #3733
When i got my ssi i figured my adapters would work but they did not thats why i did not buy one from them.
what's the point of datalogging if you have no idea what it is ?
2004 BMW 325XI AWD Turbo Auto - standalone engine and trans controller - SLC_OEM - 62mm turbo
1994 Toyota Supra Twin Turbo - AEM V2 - in the mail bugatti veyron pump, 1000cc ID, T72
2004 Nissan SE-R SpecV Turbo - standalone, j&s safeguard, modified stock injectors. (gone)
