Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
  1. #21
    Germany
    the key to prep is just turning the heat up higher
  2. #22
    Germany
    the zinc will vaporize and turn into zinc oxide, your shielding gas will blow most of it away. Just drink milk if you get the funk from welding galvanized.
    Just turn the heat up and you'll burn right through it.
  3. #23
    Hamilton,OH
    while this is true, lets not kid ourselves.....its much safer to remove the coating.
    im not going to sit here and lie about it. every form and fashion of welding is hazardous to your health, except maybe sub arc. aluminum tig is pretty bad due to the flakes of aluminum that fly around in the air that you inhale. and heliarc is worse....
    idk why i even do this...it totally fucks my sinuses up everyday. but i love to make things and melt metal together lol. its really cool when i can take a stack of plates and put them together to make something that looks super cool or does something awesome.
  4. #24
    Sep 2009
    Queens,NY
    Slapped 5 Times in 3 Posts
    Have you been practicing? I want to remove my catt lool
  5. #25
    haha yes I have, but I'm not working w/ the part on the car...if you take it off and bring it, that's a diff story
  6. #26
    Jul 2011
    A few months back we (me and b15newyork) picked up a Lincoln 220v mig with 75/25 argon/co2 mix.
    Can you weld a copper pipe to a cast iron manifold? Basically as I stated in the other thread I need to weld on a piece of piping to the manifold and then weld that back into my EGR pipe. Seems pretty simple but just not sure about how compatible the materials are..
  7. #27
    Corning, NY
    welding cast is 1 thing, welding copper with steel is impossible
    white 03 spec v
  8. #28
    Columbus
    lol why copper anyways?
    Fujita CAI, Spectra Breather, TDMI Coilovers.......to be continued.
    Parts to be installed: Kuo's QT link, Ebay header back exhaust, Eibach RSB kit....More coming soon.
    "Give me time space and money it shall be installed"
  9. #29
    Germany
    Exhaust wok need to be fitted on the car, tacked in place, and then pulled down for welding...... it's pretty much impossible to do it totally off the car unless you build a fixture.
  10. #30
    Hamilton,OH
    You could braze or solder that together. You cannot weld a ferrous metal to a non ferrous metal...
    My Engine Build-http://www.b15u.com/naturally-aspirated-na/18182-n-conservative-build.html" target="_blank">http://www.b15u.com/naturally-aspirated-na/18182-n-conservative-build.html
    Port&Polish Work-http://www.b15u.com/members-services/19127-offering-port-polish-work-%2Apaint-colors-added%2A.html" target="_blank">http://www.b15u.com/members-services/19127-offering-port-polish-work-%2Apaint-colors-added%2A.html
    Rear Strut Bars-http://www.b15u.com/suspension-chassis-braking/17257-rear-strut-bar-2.html" target="_blank">http://www.b15u.com/suspension-chassis-braking/17257-rear-strut-bar-2.html
  11. #31
    Yeah my answer was pretty much no, I'm not going under your car to weld lol
  12. #32
    Jul 2011
    Quote Originally Posted by SentraInsanity View Post
    I dunno lol I thought the EGR tube on the sr20's was copper. I dunno I could be wrong.
  13. #33
    Nick McKay seekerbeta is offline
    Aug 2009
    Surrey, BC, Canada
    Quote Originally Posted by fullah View Post
    Mines Stainless... PITA if i remember, we had to extend it for my header installation, had to wait for a piece of stainless and some different wire so that it could be welded...
    can you weld mild to stainless?
    2002 Nissan Sentra Spec-V | MagnaFlow CatBack | OBX Header |Travis Shifter Bushings | 2JR Crank Pulley | Running 15" Steelies for the SPRING! | 5ER Rad Bushings
  14. #34
    Dec 2011
    Quote Originally Posted by seekerbeta View Post
    yes, you would have to use 309 wire.
  15. #35
    Aug 2009
    Surrey, BC, Canada
    Quote Originally Posted by ELOY View Post
    and thats why i hated the shop i used to go to, they made me buy this wire for specifically doing stainless, change the gas, do all the grinding, all so i thought i could save a couple of bucks...
  1. Picked up another Pit Bull last night.. :)
    By Trav4011 in forum Open Bar
    Last Post: 03-17-2011, 08:26 AM
  2. Just picked this up from Virginia today...
    By osx86ftw in forum Member Rides and Project Cars
    Last Post: 06-21-2010, 09:58 PM
  3. FS: HID's $65 Picked Up.
    By illoosionz in forum Parts for Sale
    Last Post: 06-12-2010, 03:59 AM
  4. Look What I Picked Up today :)
    By Just-N-Tyme in forum Wheels and Tires
    Last Post: 06-02-2010, 12:52 PM
  5. Welder anyone?
    By mofoka in forum B15 Sentra (2000 - 2006)
    Last Post: 11-29-2006, 12:23 AM
