Results 1 to 9 of 9
Thread: camber bolt
    Default camber bolt
    alright got a question has anyone got these camber bolts , im getting some cuz i got the 300zx caliper upgrade and need spacer with my rims put i still wanna ride low with out rubbing ,
    I bought some and never installed them since my camber isn't off at all lowered 2" all around. Are you trying to tuck the wheels in without rubbing? You can just slot your upper strut mount for free, and it will have the same effect as camber bolts.
    i know but i want like alittle camber
    How much do you have right now?
    and my wheel are already tucked in and fenders rolled no no problem just when i put the big brakes with spacer i know it will rub
    im droped like 2 and a half or 3 quaters with stock camber
    How big of a spacer? You can pull the front fenders by following the 2J spacer install video, easy and free to do. Do you have coilovers? They may already be slotted for camber adjustment.
    for the spacer i dont know yet didnt get the my rotor yet to do the test fitting and i want the smallest spacer possible im hoping for 5mm or 6 mm and i do have coilover they are slotted i just want a little camber and you cant really tell with the slotted coilover how much your putting , i think ill just try the bolts theyre pretty cheap
    You don't need bolts if your coilovers are slotted, both will need a proper alignment to get the camber where it needs to be. What brakes are you putting on? It's the caliper that will determine wheel clearance, not the rotor.
  1. All B15 Models Camber Shim
    By sikiller15 in forum Wheels and Tires
    Last Post: 09-02-2011, 07:58 AM
  2. Anyone know the front caliper bolt size? The 19mm bolt size?
    By Specvay in forum Suspension, Chassis & Braking
    Last Post: 08-26-2011, 03:41 PM
  3. Rear camber
    By Circuit00C in forum Suspension, Chassis & Braking
    Last Post: 05-24-2011, 08:30 PM
  4. 04-06 camber bolts??? help!
    By Ricardo86 in forum Suspension, Chassis & Braking
    Last Post: 03-31-2011, 12:16 PM
  5. Camber kits???
    By b15sert in forum Suspension, Chassis & Braking
    Last Post: 01-24-2011, 11:03 PM
