When its that time to get new wheels, weight is a very important factor that needs to be considered. Heavy wheels will effect the unsprung weight on each corner of the car. The more weight there is, the more resistence there is to spin them, meaning the car will have a harder time accelerating since it needs to spin more weight in order to move. Think of it this way, put a 1lb weight on the end of a string and spin it, now put a 2lb weight on the same string and spin that, it will take more effort to spin the 2lb weight vs. the 1 lb. Now think of it this way, that 1lb weight represents your stock wheels and the 2lb represents a heavier aftermarket wheel, ideally when you choose a new wheel set, you want to either match the stock wheel weight, or reduce it. The lighter weight means less effort involved in spinning it.
Here are some links to wheel weights, both stock and aftermarket:
http://www.gti-vr6.net/library/wheel...ht/wheels.html
http://www.wheelspecs.com/WheelBrands.aspx
FYI:
02-03 Spec-V 17': 17x7 24lbs
04-06 Spec-V 17': 17x7 ~20lbs
00-02 SE, SER 16': 16x6 18lbs
lol you dont need to quote the post. iirc 04-06 were lighter then the 02-03 by a couple of lbs. around 20lbs each maybe??
opps sorry bout that. use to doing dat. k kool nice to know. thanks
on my bathroom scales, my 04 stock wheels weighed 22 lb
i have some info from 5zigen which may be useful
if you remember i choose F01r-c, 17x9, 20mm et for mine
most popular here is the same wheel with 35mm et
well come to find out, the 35mm et wheels are much lighter [2lb]
check here
5ZIGEN USA OFFICIAL SITE EXHAUST WHEEL RACINGGEAR
i choose the wider tread unaware of the weight disadvantage [15mm spacers weigh less than 2 lb each]
As mothers and fathers
Sisters and brothers
Sons and daughters”
Let us start here
ok hoefully someone will answer my question my rims+tire at proper PSI is 45lb... is that alot?
04 wheels weighed 22lb on my bathroom scale
Sons and daughters”
Let us start here
i'm not sure what the question is?
i run 225/50/16 tires most times
in dd i use about 35lb
mountain runs 38lb
tricks, stunts, slips, and slides about 42lb
and 23-25 at the drags
i imagine for auto-x between 38-42lb
does that help
don't use the max pressure listed on the tire side, use what's listed on the car to start with.
Sons and daughters”
Let us start here
is that including the tires at proper psi?
a stock wheel weighs [04-06] about 22lb
most 215/45/17 tires weigh aprox 22lb [21-24lb range]
that would give you a 44lb wheel tire combo
your only one lb from that average weight
well within reasonable limits
[tire pressure does not significantly change wheel weights within normal limits]
a lighter combo would help acceleration and braking by a small amount
car feels lighter on it's feet with 36lb wheel combos
imo
Sons and daughters”
Let us start here
A tire weighs 22lbs? That doesnt sound right
Sent from my LG Thrill
What's done to your car? It's easier just to tell you what's not done to it....
here is the best true street tire i know [21lb]
Michelin*Pilot Super Sport
typical auto-x tire 25lb
http://www.tirerack.com/tires/tires....=yes&tab=Specs
drag radial 23lb
BFGoodrich*g-Force T/A Drag Radial
popular street tire 21lb
BFGoodrich*g-Force Sport
new model got heavier 23lb
and a very sticky long laster 21lb
most will fall between 21-24 lbs
drag slicks will be lighter in the same size
as will most comp rr slicks in this size
all stats from tire rack
Sons and daughters”
Let us start here
Something else to think about is wheel/tire size altering gear ratios. I DD 04-06 spec wheels with 215/45/17
I autox 15x7 rx7 wheels w/ 195/50/15. Roughly 31lbs at proper air pressure. Its a huge difference in accel, braking, hard cornering etc. The tires I run are shaved R1Rs
Sent from my DROID RAZR using Tapatalk
'02 Inferno GXE 5spd
Show off/Build Thread
thanks guys I thought my rims were heavy since I have xxr 962 17x9 all around. does anyone one know the weight of the nismo rims with tires?
