1 - 20 of 97 Posts
I have a full 2003 Sentra Spec V with around 216k miles on the clock that I'm parting out. I already got rid of the chassis and here are the left over parts. All sold items are marked as sold.
All prices are OBO, please add paypal fees, will work with you on combined items and shipping. Location is Harrisonburg, Virginia.
iTrader Feedback Page
Available Items:
Engine - $300
216k Mile Gauge Cluster - $50
Random Interior plastics (ask)
Glove box - $25
HVAC Filter housing - $25
Overhead handle bars - $5 each
Center Console w/o Shifter surround - $50
Black door handles - $7 each
Black Gas door - $15
clock spring - $30
gas pedal - $40
Light switch - $25
Wiper switch - $25
Cruise control module - $20
Window motors (Without brackets) - $20 each (Driver side Sold, Passenger Sold)
remote door locks - $25 each
Brake Booster - $20
Driver tail light (has a broken piece) - $30
handbrake and cable - $30
Gas tank Opener cable - $15
AC interior expansion core - $30
Quarter panel windows - $25
Reverse light/plastic - $20
Lower trunk plastic - $5
Spoiler (without brake lights) - $35
Muffler - $30
aftermarket stock size catback - $30
Xmember - $30
Motor mounts - $40
Engine cover - $25
Front Strut bar - $70
Steering rack - $50
Aftermarket 2000-2001 style front bumper - $45 (Pickup only)
Body Harness (was cut inside) - $45
Tie rods - $10
Vapor Canister - $25
Spec V Grey Interior and Cards - $250 Picked up - Available
Pictures All Items:
Engine - $300 - Available
Transmission - $150 - Sold
Coilpacks - $50 - SOLD
Manual HVAC controls - $20 - SOLD
Center console pocket and vents - $30 - SOLD
Map Light - $10 - SOLD
Dinn Cubby - $10 - SOLD
Carseat hook plastics - $20 - SOLD
Front Door plastic trays - $10 - SOLD
Radio Plastic - $5 - SOLD
Door Handle Covers - $5 - SOLD
Glove box - $25
Oh crap handle bars - $5 each
Lower pocket center console surround - Sold
More random plastic (ask)
Cup Holders and Shift surround with boot - $30 SOLD - Boot has a hole and plastic has two holes drilled where ashtray would be.
Seat belts - $30 - SOLD
Steering wheel - $35 - SOLD
clock spring - $30
gas pedal - $40
Light switch - $25
Wiper switch - $25
Brake Booster - $20
Fuel Pump Assembly (good for modding) - $35 - SOLD
ECU Harness - $40 - SOLD
2003 ECU (Non Nats) (*5ZE1K3* - JA56U87 BR4)- $50 - SOLD
Passenger Tail light - $35 - Sold
AC Condenser - $30 - SOLD
AC interior expansion what-ever - $30
Door weather stripping - $25 - SOLD
reverse light/plastic - $20
trunk plastic - $5
Control arms - $40 - SOLD
Radiator fans - $30 - SOLD
vapor canister - $25
Axles - $100 SOLD
Hubs - $80 SOLD
Catted manifold - Pending
muffler - $30
Xmember - $30
Motor mounts - $40
Transmission Mount - $30 - SOLD
Engine cover - $25
strut bar - $70
Spec mesh grills - $50 - SOLD
Steering rack - $50
Under 100 mile TYC headlights (one tab slightly drilled out) - $70 - SOLD
Interior Door handles - $15 - SOLD
Trunk Opener, dimmer, mirror controller - $25 - SOLD
Master cylinder - $10 - SOLD
PS reservoir - $10 - SOLD
tie rods - $10
Only tear on one of the seats
Rear seats:
Door cards
The Wheel Ninja
Location?
Is the gauge cluster in fully working condition? Still available?
Thanks
Good, I have a fully functional gauge cluster, except my coolant temp gauge failed. I just want to make sure it all works before I make you an offer. I have to also check on the process of re-calibrating that cluster for my mileage.
I'll let you know.
Discussion Starter · #13 ·
I actually don't know if you can do that, or if it's legal, but it's worth the shot asking. I also think it is possible to (at least it was on older B14's, to swap just the coolant gauge).
I'm going to check into it at work. We order new clusters and send them the mileage number to program into the new cluster. I *think* they can do it if its ordered by a dealership that verifies the car's ownership, actual mileage, etc.
I think it will work, I'll let you know what I find out tomorrow.
These are not modular like the older Nissan clusters. I had mine and an 04 b15 cluster apart today hoping I could make one good one. It might be possible with some better soldering tools than I have, but it looks like I'd be more likely to screw them both up than fix one.
Discussion Starter · #18 ·
Interested in the vapor canister and trunk surround. What condition is the trunk surround from 1-10?
Yup got the vapor canister, do you need just the canister or the solenoid too? I'm not 100% certain the solenoid was fully functional.
As for trunk surround, are you talking about the weather stripping?
Still got the headlights are they for the 02 style? How much shipped to 40217?
Thanks,
Bret
Yup got the headlights still, 02-03 style, they are TYC's. Can do $70 shipped/paypaled to that zip.
Hey do you still have the gauge cluster and the ECU? Is the ECU nats or non nats, I need one compatible with a 5L. Thanks
Got the gauge cluster and ECU yes. The ECU is non NATS, a regular homedepot cut key worked fine on it.
That sucks, but makes sense for them to finally integrate them.
Just and FYI I try to go by the first come first serve basis and I do favor combined item purchases (makes life easier and cheaper on shipping for me), so if Kojonissan agrees to purchase the cluster first, it will go to him.
Its cool, my parts department doesn't think its possible to reprogram used clusters. I'll look for one that's just over my mileage and swap it out when I get there.
Thanks anyways
1 - 20 of 97 Posts
