This is true. That's why I've always replaced them in pairs.FWIW : If the bearing is really bad and allows excessive play, it may damage the inside of the hub. It will not be excessive, but even 1mm can cause the new bearing to fail prematurely.
This, however, isn't. The bearing and hub needs to be installed separately. The bearing is locked in with a snap ring behind the hub. So the hub needs to come out first, then the snap ring, then the bearing. I wish it was as easy as some of the Chryslers like those minivans. 3 or 4 bolts (can't remember) and they're out as an assembly.You can get a loaded hub with the bearing already in for not much more. Check ebay and amazon; pretty good prices and saves you the $40 and driving time of having the old pressed out and new one in.
you can use something like this to remove the bearing off the old hub. If your bro has a press in his shop i'm sure he can help you out and might already have everything you need.Thank you for all of your responses! My brother-in-law has a press at his shop so I think i'll try using that. The only problem is getting the old one off now. Can I use a press to remove the old one?
