1 - 4 of 4 Posts
Ok so I have electrical issue battery died got new battery now I'm not getting power to the starter put test light on power wire from ignition while I had someone turn key nothing no light does this point to bad ignition I clean terminals one time and it tried to start but after turning key second time trying to start it went back to 0 power
So you haven't checked the fuse or relay yet, sounds more like the cable is either loose or broken as the positive terminal is damn near directly connected to the starter iirc... car not in front of me.
Discussion Starter · #4 ·
So yea I fixed the starter issue the ignition wire has shit connection but now it just cranks and cranks so I grabbed crank and cam sensor off Amazon I'll know it this get me back running Fri
1 - 4 of 4 Posts
