1 - 2 of 2 Posts
seller name: RJ Cornine
Price: $8,500
vin: 3n1ab51d93l726978
I am selling my 2003 Nissan Sentra SpecV. It is in good condition and runs great! It has twice as much as I am asking in just upgrades. $1500 in suspension alone! Everything in this car is quality parts. No china junk. This car was built for fun and reliability not all out race. You would not even feel like this car was any different than stock cruising down the road. I am only selling because I have 3 small children and am in need of something larger. I do still owe a little money to truliant credit unit on this car. It has 50,000 orginal miles (yes 50K). I purchased it stock from a guy in the military who couldnt drive it much. All parts on the car have 10,000 miles on them or less. I have only put 10,000 miles on the car since I purchased it. I am not looking to give the car away as it does suit my needs just looking to upgrade our smallest car to something with 3rd row seating. I might be willing to take a partial trade plus cash on your end for the car. Just contact me with any questions you can text me at 336 259 6119 or message me at dyn6189 aol.com
I am listing all of the upgrade and options that I can think of.. I am sure I will miss some.
Stock Features:
2.5L 4 cyl engine w/6 speed limited slip transmission (170hp/175tq-flywheel)
power windows
power locks
power mirrors
cruise control
a/c and heat work perfect
power sunroof
Nismo floor mats (still new in plastic)
Upgrades:
Engine:
Full Treadstone top mount Turbo kit with upgraded Garrett t3/t4 60trim turbo w/jet hot exhaust housing coated
Turbonetics Evolution Wastegate 5lb spring
Tial Blow off valve
Turbonetics Manual boost controller (set to 9psi)
Apexi SAFC2 for tune
AEM Wideband o2 setup (steering column mounted)
DevilsOwn Alcohol injection set up 5gph nozzel
ProThane Solid motor mounts
JWT Balance Chain removal kit
2.5" from turbo to ground then 3" from front to back (recirculated wastegate)
3.5" qtp Electric Cutout (switch mounted in center column)
3" super turbo muffler w/dump (high flow rate with low tone)
Exhaust temp probe installed under engine
Water temp in a Water temp adapter pipe
Oil temp sensor installed on rear of motor
NGK one step colder platinum plugs
Stage 4 Sprung Competition Clutch
mobile1 full syn oil always used
REDLINE Heavy shockproof full syn trans fluid (thick when cold)
Strong engine! Never a Check engine light passes obd2 no issue every year! RELIABLE
INTERIOR:
AEM Wideband o2 on steering column
Custom made 3 gauge dash pod
3 gauge 60mm A pillar pod
Blue shift light w/built in rpm switch
Digital fuel pressure gauge in dash pod
Digital voltage gauge in dash pod
Digital Exhaust temp gauge in dash pod
Analog boost 7 color memory gauge in pillar pod
Analog water temp 7 color memory gauge in pillar pod
Analog oil pressure 7 color memory gauge in pillar pod
Programable turbo timer
Sony Radio relocated to bottom bin
B&M short shifter kit
Blue Activation light for Alcohol injection(functions on boost switch 2+ psi it kicks on)
Red warning light for Alcohol fluid level (comes on at 1/4 tank)
Rare Klm gauge faces for cluster (has mph on inner circle)
Alpine type R speakers in front and back
EXTERIOR:
Full GXE sentra front end swap (for sleeper look included front bumper and fenders)
New Headlights w/6000K HID
Full 2004 Sentra Rear end swap (all red tinted tail lights OEM and 04 bumper)
Nitto Neogen tires
Koni Yellow Adjustable shocks All around
Eibach Pro lowering springs
Fresh tint job From Protint with transferable lifetime warrantee
BAD:
Random dents and dings from living in a Townhome with apartment style parking
Might be a couple small stains on rear seat from my children
trunk lid had a dent in it by the license plate
sometime you may have a slight vibrate from exhaust (3" is large)
Solid motor mounts coupled with balance shaft removal kit make the car vibrate at idle doesnt hurt anything.
Stage 4 clutch is heavy.
I do not HAVE to sell this car I am wanting to sell or trade +cash (on your end) to have something a little larger for comfort. I am wanting 3rd row seating possibly a mini van. I have tons of money tied up in this car and It is all done right. All quality parts that are made to last. The miles are unherd of on this year. It is ready to be driven and enjoyed by someone else. The car doesnt need anything. please do not waste my time with money order offers or anything like that. It has a clear title that is being held by truliant until paid off. The car is in overall good condition with minor dents/dings/scratchs from normal wear and tare. It leaks no fluid and burns no fluid. Very fun car to have if you have any questions feel free to text or email me. I am 100% honest and do not hide anything.
Thanks for looking,
RJ
336 259 6119
dyn6189 aol.com
1 - 2 of 2 Posts
