Both fans working! I feel stupid but here's the story.
I checked my radiator fan fuses inside the engine bay fuse box. Both looked good. Then I tested for electrical connection via multimeter in the pigtail connector of the none working fan.. it was hard getting the multimeter needle in the connector while holding the multimeter while upside down under the car while trying to touch a ground connection with the other needle.. so I was reading +/- 0 Volts... Not sure if I did the test correctly but I assume I was getting no power there..
Working under pressure since it was late (11pm), needed the car on Monday, and looking at the tools and garbage I need to clean up after I am done, I decided to just slap on $30 universal radiator fans from Amazon, hoping and praying it would just magically draw power. I drained coolant, took off radiator, detached old fans, and installed new ones. I ensured both fans are pushing air into the engine since that was how the old ones were setup.. I turned on ignition and one fan was still not working.. I decided to just sit down for a few minutes and decided to look back at the notes and my old posts from when I put together the car in 2017... I decided to check the ground connections for the fans.. the ones that were supposed to go to temp sensors but I didn't because I was cheap... I followed the wires with my finger. One lead to a ground (good). I followed the other wire with my finger and noticed the wire was very loose.. so I decided to give it a tug.. that was when I noticed that it wasn't connected to anything..
I connected the wire back to the nearest ground I could find and turned on ignition. BOTH FANS ARE NOW WORKING!! 🤣🤣
How it happened:
Last November I was fixing a never ending exhaust leak and emissions code after getting a 2J email tune. I took apart and reassembled the intake manifold 1000 times looking for a leak.. It ended up being an exhaust leak on my Y Pipe.. so I was looking at the wrong place and had backwards secondary o2 sensors... (Long story)
Anyway I ended up fixing that exhaust leak code and drove happily ever after. I must have just forgot to replace the ground for the radiator fan during one of the intake manifold reassemblies.
I am now kicking myself because I have to put the radiator back on and refill coolant etc... I had no idea why I thought putting in new fans would make it work even though I know that there was no power there.. Also in hindsight, I could have just plugged the new fans into the pigtail connectors to test without taking out the radiator and see if it would "work" 😤. I guess the brightside is I now have new fans.
I have finished reassembling everything and I am now in the process of putting in coolant. I always get anxious doing this because I can never get it to burp by myself.
I have 3.78 Litre jug of Nissan Coolant and I mixed it with the same amount of water. The front of the car is on two jackstands, a jack, and the rear wheels are chocked to help prevent moving. Basically I am trying to simulate an incline.
I have filled the radiator and coolant reservoir with the mix. Currently there is 3.78 Litres in the car. I know more can go in. I believe these cars take something like 11 litres. So my remaining mix plus a bit more water should go in but isn't... Radiator cap and coolant reservoir cap is off. Car ran for 15 minutes but didn't burp too much.. I even squeezed the upper and lower radiator hose but I am scared to do more because it is quite hot. Last temperature reading was 86*C so it is warmed up I believe?
I had to call it a night (1am) since car was loud and didn't want to piss off my neighborhood..
What can I do to speed up burping tomorrow? Also I am extremely low on gas.. I haven't filled up in a while...
