1 - 4 of 4 Posts
So I’m not sure what else I’m missing besides needing all new bulbs, but I doubt they’d all go bad at the same time. The 3 bulbs are not working, but the amber A/C, recirc. and rear defrost light up as they should.
1)I’ve checked all fuses, they’re all fine. Even the ones under the hood.
2)Everything is wired correct for the radio. Grounded to chassis.
my next step is get new bulbs and tear everything out again, but would like to know if Anyone has had this problem before.
Did you have to mess with it or unplug anything during the radio install? Those lights are sometimes problematic for me. but only because I use white led bulbs. But also maybe by chance that they burnt out or you happened to notice it then ???
Did you use a patch harness to install the radio, you shouldn't have to ground anything if you did unless you have some kind of special head unit.
I had one bulb go out in mine. Replaced it and when i put everything back together the other bulbs were out. I pulled it apart again and one of them fell apart in my hands.
1 - 4 of 4 Posts
