1 - 17 of 17 Posts
Hey everyone! I recently bought a 2016 nissan sentra S and have been having trouble getting the car to pass smog as the EGR is not ready. Ive driven hundreds of miles with no luck and I cant seem to find an EGR on this car. I was wondering if anyone has any insight or is able to show me where the EGR is on the 2016 nissan sentra so that I can try cleaning it out. Thank you in advance for any help!
Administrator
You shouldn't have an EGR, give us the code and we can go from there.
The car actually has no check engine light on, all the monitors are complete and ready for smog besides the EGR so I assumed it did have one. I’m not sure if it’s an electrical issue or if there is something else I can clean out/replace that would help get the EGR monitor ready.
Administrator
It won't as there is no EGR, you can't ready something that's not there and if the tester fails you for that then there are other issues. If you are not throwing a code, even a soft code, then there is no issue as an improperly working EGR would throw a code.
Yes one monitor for every state EXCEPT California. The fact that its not ready is a mystery. EGR is continuously not ready?
Discussion Starter · #7 ·
Thank you for all the insight. I thought I was crazy when I couldn't find the EGR but its relieving to hear that it doesn't have one. I'm really unsure of where to go from here, maybe its an electrical issue or maybe there's a backstory with the car that im not sure of because I had bought the car off craigslist a year prior and haven't had to smog it until now. If anyone has had a previous issue in the past or can give me any suggestions on where to go from here that would be of great help. Yes i am in California and the only monitor that can be not ready is the EVAP montior system, EGR must be ready in california. Heres a picture of the smog readiness that my scanner is showing, ive used two different scanners and they both show that the EGR isnt ready. The car also only has 25k miles so im really unsure of where to go from here.
172458
Administrator
I don't understand how it says it's not ready if it doesn't have one... I'm familiar with the MR motors as there was one in my wife's versa... weird.
Discussion Starter · #10 ·
thank you for the insight Kev, I have personally not done any modifications to the car and have just done routine maintenance, but the previous owner may have done one of those so I will do some further investigating and see if there is anything off with those. thanks again! If you dont mind, would you be send me where you had found that information? ive done a good deal of googling but can not find anything inregards to the EGR with this generation sentra.
It wasn't a Sentra but could still be something to check because it would be similar.
That's weird that it doesn't have EGR marked as unavailable. IIRC the engine will adjust the camshafts valve overlap to leave a bit of exhaust gas in the combustion chamber instead of using a physical EGR valve. Then again I have never checked readiness monitors on that gen sentra before. Typically EGR would most in use at or just off idle. Maybe let the car get to operating temp and let idle for 20-30 min with no loads i.e. radio, hvac, defroster, heated seats, ect.
Discussion Starter · #13 ·
Just tried that after reading your comment with no luck. I was hoping that having no load and it being much colder right now than the past several weeks in California may have helped but the EGR is still showing as incomplete. Thanks for the input though
HI. ABOUT THE EGR NOT COMPLETING ON YOUR 2016 SENTRA, DID YOU EVER FIGURE IT OUT? IM HAVING THE SAME ISSUE. NO CODE, NO PENDING CODE, NO PERMANENT CODE, DROVE IT OVER 800 MILES AND FOLLOWED MULTIPLE DRIVE CYCLES. STILL NO LUCK ON COMPLETING THE EGR READY MONITOR IM
You need to take it to a dealership. Consult 3 will tell a technician why it is not ready.
[QUOTE="FRe, post: 1744525, member: 1497
Doesnt that mean getting charged 3 different times just for different opinion on inspections?
1 - 17 of 17 Posts
