1 - 20 of 21 Posts
Ill take them. Pm me ur paypal
I’m just asking out of curiosity but what are the pros and cons of switching out pulleys? Horsepower gain? Reliability due to less strain on the engine?
Reduced rotating mass freeing hp & tq from parasitic losses.
Harmonics from the rotating assembly, and that varies from engine to engine and rpm.
Moto IQ did a article or two in them compared to oem and aftermarket dampers.
I took mine off and put the stock crank back on, that has that little dampener, and I can tell you my steering wheel didn't have as much vibration
With the QR? Because I mainly found BRZ
for the QR? Because I mainly found BRZ.
Same concept with any motor, results may vary as balancing will play a part if it is internal vs. external balanced as well which I don't think they go over.
Many people have ran a light weight pulley with no issues on this motor including myself and if you are a 1320 guy then it will be fine as you are not maintaining a window of the rpm band as with road racers.
Then you have other issues as the damper, or lack there of, will not send vibes through the chassis and not just the steering wheel. If this happened then it would be more prominent at certain rpms if you maintained it there or went through the entire rev range slowly.
Discussion Starter · #20 ·
When your on the freeway the rpm is pretty consistent. It wasnt to garing, just wasnt what I wanted in my daily
1 - 20 of 21 Posts
