I'm doing uprec conversation to my 03 spec v on tje 2j ecu there are a bunch of connections numbered like 62, 17 113 114 and so on qhere do those connect toWhat’s the question?
k6There are 4 different combinations. Depends on the ecu you have and ecu you will run. Which ones do you have? Just give me the 2 digit code, k3 or k6 to r4 or r5? If you have r5, did Joe turn the nats off the 06 ecu?
So you have nats.
ok awsome and then what about the maf sensor if I were to take pic could you tell if I spliced them right. then the small wire coming from the connector for the o2 sensor is that a groundSo you have nats.
If the black ecu has r5, then use this combo - 29-114, 62-13, 71-14
If the black ecu is r4 then use this - 29-113, 62-14, 71-13
also my gauge cluster isn't lighting up or working I appreciate all your helpSo you have nats.
got it now I'm just trying g to figure out why cluster isn't workingalso my gauge cluster isn't lighting up or working I appreciate all your help
ya got wiring down only thing not working is cruise control buttons for tune. and I got maf hooked up but car idles weird then diesDid you do the wiring swap on the cluster? It's not plug and play.
It is and it isn’t. It’s like trying to tune the 00-01 rr with a downstep b14 ecu.This sounds easier to just pick up a 04-06 for cheap, or sell and buy one.
yes got that wired up no codes just oil light on and still no cruise control for tune and no tachometerAny codes? Did you get the can wiring from the cluster to the obd port?
ok so the can hi and can lo it says something about tieing into yellow wire on cluster🤔yes got that wired up no codes just oil light on and still no cruise control for tune and no tachometer
ya it has maps on back of ecu and he told.me that he put them.all.on and ill send a pic of how maf is wiredHow was the MAF wired? Were you able to follow that easily? It could be the maf or the wiring for that code.
As far as the map switching, depends on the map that's actually loaded into the ECU. Did Joe mention that he loaded multiple maps in there? I know there were different versions of the ROM and some ROMs only had 1 like @MisterNuts. He has an 04 ECU and has a rom that only holds 1 map, while others I know have the same ECU but have 5 maps opened up from Uprev.
