Can you take a picture of the maf wiring and connector?
hey buddy have a quesrionCan you take a picture of the maf wiring and connector?
my maps arnt switching and idk wjat tondoWhat is it?
yep i tried that both ways set does not flash wiring seems to be right nothing is off and wires are in right spots.Asumming you already tried what I underlined/bold?
Using the Cruise Control Buttons...
-Hold the set/coast toggle down
-Press "Cancel" once for map 1, twice for map 2, etc...
-Then release the set/coast toggle.
-When you release the toggle, the cruise "SET" light on the dash will blink once for map 1, twice for map 2, etc... There are also a FEW vehicles that require using the brake pedal instead of just the cruse switches. For these vehicles use the same pattern as above, but hold the cancel button while tapping the brake pedal.
check engine will flash when its in acc position but thats itWhen you turn the car on, not start the motor, after 20-25 seconds or so does your check engine light start to slowly flash?
and ive tried maps when engine is warm and coldcheck engine will flash when its in acc position but thats it
how did u fix the idling and dying issue ?ya got wiring down only thing not working is cruise control buttons for tune. and I got maf hooked up but car idles weird then dies
starts strong then sputters and dies. i must have wired the maf wrong, but i followed up on some older posts by moltennismoI had this issue, had the car toewd to my tuner and he did something and got it dialed in.
and what about the black wire coming from the o2 sensor?I had this issue, had the car toewd to my tuner and he did something and got it dialed in.
This is correct, right? dont mind the electrical tape lol.Can you take a picture of the maf wiring and connector?
