1 - 5 of 5 Posts
I recently bought an altima 2j plenum and i got it all bolted on and all the vacum lines ran into the plenum. But the car will not start it just cranks and cranks. I had to Y off some vacum lines into the same port since the stock b15 manifold has 5 ports while the altima plenum has 3. Please need help getting this car to start with the new plenum. Ill post pics once 8 get home from work.
Discussion Starter #2
Oh and also i dont have my original TB on i used the one that came with my new plenum
It's a straight forward install... but I can see the need for disconnecting a few harnesses and the first thing that comes to mind is the cam sensor not being plugged in or shorted.
^^ That or the fuel injectors were not plugged in. Double check your connections.
Also did the new TB actually plugged in? Was it the same type or the newer one? You'd def need a converter harness for the newer ones that bolt directly to the plenum.
Was thinking fuel. But try the oem tb
1 - 5 of 5 Posts
