1 - 10 of 10 Posts
My question is, If I have a 5 Channel 1100w class D amp with a sub channel, can I run 4 ohm speakers and a 2 ohm subif the system is under 1100w
Its a 5 channel
80 rms x4 channel & 350rms x1 channel at 4ohm
125 rms x4 channel 2 ohm & 600rms x1 channel at 2ohm
I plan to get 75 rms speakers at 4ohm and want to get a 2ohm 400rms sub. Is that possible?
Interesting. Im no amp master but I run 100w 4 chan @4 ohm, and a 1 chan 600W @2ohm together. Meaning I havent seen the specs rated for all only 5 chan 4 ohm or 2 ohm .
I think the description is a bit misleading. This is the amp I run and probly exactly what you are looking for for $50 extra.
I was looking at this amp but what put me off was that it didnt have a subsonic filter. I listen to alot of bass and dont really plan to go further than this build for at least 5 years so I dont want anything damaged by some bass boosted song.
I was suuper tempted tho. But the nvx,when it restocks, comes with an ofc amp kit that will save me a good bit
1 - 10 of 10 Posts
