Hey guys as some of you may already know I blew my completely stock qr25de after I went Boost. Since then things have gotten kinda hectic with me losing my job and now being on unemployment to family members going threw some serious medical issues. "UPDATE" Ive since then landed a good job working for a local Nissan dealer and for the past few months now I have been saving up and researching. Just recently as of this past Monday 7/21/14 I sent my motor off to Joe at 2J-Racing for the Build. My goal is to make 450whp safely on E85.
My Motor build Sheet:
Used 02-03 qr25de block- Free
Used qr25de cylinder head cleaned, inspected and checked for reuse
used stock pulleys
new oem complete gasket set
new oem timing set
new oem oil pump
new oem water pump
new oem belts
new oem sensors
used 07 crankshaft turned and polished
new 07 crankshaft signal plate
new 07 crankshaft signal plate bolts
New 07 Upper Intake Plenum
new wiseco piston rings
new arp rod bolts
new arp main bolts
new arp head studs
new Cometic tri-layer headgasket
new acl bearings custom specd
new jwt bsr kit
new 89.5mm forged low compression 8:5:1 wiseco pistons
new 2JR forged H beam rods
new 2JR Valve Springs
new 2JR Stage 3 Clutch
new 2JR Lightweight Flywheel
new oem throw out bearing
new arp flywheel bolts
new 2JR Fuel Pump
new 2JR 1100cc Injecters
Mishimoto Radiator
Mishimoto Dual Slim Fans
2JR Radiator Hoses
slight bore an hone to clean cylinders for 89.5mm pistons
blue printed/balanced rotating assembly
Turbo Setup:
Turbonetics t3/t4 dual ball bearing/dual cooled turbo
Treadstone manifold
Treadstone 2.5" black hotside intercooler piping
2JR Custom 3" Intake intercooler pipe with maf housing
Tial 38mm wastegate
Tial Q Bov
Crawford Racing Oil Catch Can
Prosport 52mm boost, oil pressure, water temp gauges
AEM Eugo Widban
2JR Uprev tuned
2JR vacuum block
2JR 3" midpipe/catback
High Flow 3" Rez
Custom 3" downpipe heat wrapped
Vibrant gaskets
Treadstone oil feed/drain line kit
NGK 1 step colder spark plugs
Nissport oil adapter
hallman pro boost controller
Greddy turbo timer
AEM dry flow air filter
2JR Turbo Blanket
Is their anything that im forgetting or that i should add. Thanks B15U!!!
***PICS AND PRICES FOR THE BUILD COMING SOON***
used stock pulleys
new oem timing set
new oem oil pump
new oem water pump
new oem belts
new oem sensors
new arp rod bolts
new arp main bolts
new arp head studs
new jwt bsr kit
new 2JR Fuel Pump
Mishimoto Radiator
2JR Radiator Hoses
Turbo Setup:
Treadstone manifold
Tial 38mm wastegate
Tial Q Bov
AEM Eugo Widban
2JR Uprev tuned
2JR vacuum block
High Flow 3" Rez
Vibrant gaskets
Greddy turbo timer
2JR Turbo Blanket
