1 - 3 of 3 Posts
Does anybody know how to override the A/C compressor? (Making the compressor clutch engage by bypassing the switch) I've seen this done with other cars using a paper clip to bypass the relay. Anyway, let me know, if you guys do know how. Thanks!
??? why would you want to do that? Sure it can be done the same way by removing the relay or running straight power/ground to it.
Umm, to test if the compressor is working, before I replace it? So, has anybody done this before? Could you let me know which relay, to pull and jump. Thanks!
1 - 3 of 3 Posts
