1 - 20 of 41 Posts
Dont pick up a mishimoto or a CXracing. The neck is so high the coolant can't even drain from the overflow to the neck..
I have a Mishimoto and i agree with frozenbarb about the radiator cap. I added a fiber was her to the cap and the problem is gone. I have use mishimoto before for another car and stand behind the product, however the neck lacks design. other than that it fits very nicely. i can submit a pic about how i modified the cap without voiding the warranty. Also another member told me if you use the Nismo cap it also gets rid of the problem....
- The stock fans also fit well. its a tight fit but once the rad is in it fits and looks very nice. The slim fans from mishimoto make for a much cleaner look but for my purposes the stock fans are great. Runs nice and cool.
I just bought a mishi rad...so what did you have to do to fix that problem??
BDSF
+1. My Mishi still (after being replaced under warranty) doesn't pull fluid back from the overflow, and I'm running the Nismo cap.
I placed a fiber washer in-betwee the lower seal on the radiator cap. This has now fixed the problem :D i can send a picture if you want. The reservoir tank now flows properly.
I can give you measurements for the fiber washer and how to put it on the cap if you all want.
i have koyo and i like it. it looks very clean as well.
yes please if you would...and the nismo cap fixes this too??:thinking:
BDSF
Please do!
1 - 20 of 41 Posts
