1 - 12 of 12 Posts
I recently bought a 04 Spec-V and I'm loving everything except that it sucks gas. I get ~16mpg, and I've noticed people who claim to be in the upper 20's city and 30's hwy. I'm wondering if anyone has any suggestions for improving gas economy.
Stay under 3k rpm llol
Don't press, cruise. MY buddy's spec got 26. Stock except for intake, header, exhaust. And like 5 resonators. He freewayed 60 miles a day at literally posted speedlimit in the slow lane. So it is possible.
Sounds like you may need an actual tune up and some maintenance as I have never gotten 16 mpg at any point. maybe low 20s.
On the internet, everyone gets good numbers. If you are worried about mileage, add an intake or wire in a safc or do something to lean it out.
Helllll no. Wrong for so many reasons.
Couple things. Check spark plug condition. Fix any cel. Use 91 octane atleast (called for from factory). Tires at 35 psi.. May have to dig deeper if all the obvious stuff is good.
Some other info is needed. You need to know your mods if any or if it has a tuned ecu. On the norm it should be a solid mid to upper 20s mpg
Get a tune-up, with a fuel system cleanout. Check plugs and filters, tire pressure and use those upper gears - no reason you can't get 20+...pic from 6 years ago for attention. mileage.jpg
OP, are you new to driving stick? I always got 27-33 with mine (1st-4th-6th typically) unless I was really banging it around/playing around then I only got 23-25.
FE 🔫 CEL
bruh, I average 17 mpg, but that's because im running on my "performance" map all the time lolol 2JR Reflash.
but yes drive under 3k, and drive like a granny all the time you'll get your 28mpg. lol but wheres teh fun in that.
1 - 12 of 12 Posts
