1 - 1 of 1 Posts
Im learning about this turbosmart eboost 2 ebc. Its a bit confusing at first, ive been watching videos and reading the instructions over and over to familiarize myself with it better. I did the initial setup where you have to adjust overboost shut down, your cylinders in the set up menu. Its the boost group menu im a bit confused as i need a dyno for it, im sure i can do high gear pulls to adust set points, and gate pressure on the highway. My vacuum setup is the basic setup where port 3 on selenoid is to atmosphere as is top port of wastegate. But the gauge also shows no boost readings, and stays at times -1 or 2. Its wierd. Hopefully someone coukd give me some helpful experience on how this works. Thankyou
1 - 1 of 1 Posts
