After almost 18 years I have my first real problem with the Xtrail.
Reverse works normal but when in Drive the Xtrail starts off very slow even though the revs are up at 3000rpm. Speed slowly increases and drives normally once in motion.
Diagnosing the problem further I find the transmission does not shift into 1st or 2nd gear and always starts off from rest the same way, as though it is stuck in 3rd gear.
So researching through the service manual I find there are 2 shift valve solenoids A & B which control gear changes in the transmission. They both go through a combination of off/on changes to select a gear and I find looking through the table that if Shift solenoid B was not working then 1st and 2nd gear would never be selected.
173159
This I think is my problem and I will check the wiring and solenoid resistance to see if it is bad before I take it to a transmission specialist for repair.
Wondering if anyone with an auto tranny has had a similar problem or might know what else to check.
Discussion Starter · #2 ·
Well, on further investigation, there is no overdrive either.
I found in the service manual, how to put the TCM into diagnostic mode to visualise flashes of the O/D lamp in the dash to show faults.
First problem is that the O/D lamp did not illuminate for the 2 secs indicated in the first step of the procedure. Found the main TCM 10A fuse was blown. So replaced it and the diagnostic sequence was done with no faults showing.
Then proceded to reverse out of the driveway and upon driving up the road, the fault was still there. Pulling back into the driveway and re-entering the TCM diagnostic mode showed the O/D lamp again failing to illuminate for the initial 2 secs so the fuse was blown again.
Further searching the power diagrams in the service manual showed that the reversing lamps are powered by the same fuse as the TCM. WHY ??? What seriously flawed piece of logic did Nissan use to come up with this idea ?
So now it is off to find out if it is the LED reversing lamps or the reversing sensor control box which is faulty causing the fuse to blow when put into reverse.
Atleast at this stage it seems the TCM and the mechanicals of the transmission might be fine.
Discussion Starter · #4 ·
Yes it does have a revolution sensor in the transmission.
I added the LED lamps quite a few months back. They are auxiliary to the OEM reversing lamps in the main rear lights. I'll be chasing the wiring incase one has shorted to ground somewhere through rubbing.
Discussion Starter · #6 ·
Update ... disconnected the auxiliary LED reversing lights, reversing camera and reversing sensors which were all powered from the reversing lamp circuit. Fuse replaced and transmission fine with diagnostics showing no faults and all gears back.
I think some water may have gotten into one of the auxiliary LED lamps so I'll run a dedicated circuit now for those items once I find which one is causing the short and replace it.
