1 - 8 of 8 Posts
I'm going to sell my 1.8S so I'm dumping my horde. All prices are OBO and include shipping/fees. Paypal only. Everything ships from Oxnard, CA (if you want to pickup locally, PM me to make a deal sans shipping). Most parts are new, see descriptions.
1st post: upgrade parts
2nd post: OEM parts
3rd post: $5 clearance
Upgrade parts
$50 OEM strut tower bar taken off a 01 SE, touch of surface rust
172797
$80 Air diversion panel, 04-06 stock brackets aluminum. I ordered raw; had a friend Type 3 hard anodize it, never installed. Made by mikeygarcia406 (02-06 - 02-03 & 04-06 air diversion panels)
172798
$35 Strut top mount isolators by speedricER, new (Strut Top Mount Isolator/Spacers)
172799
$50 B15 Billet rear strut mounts, bought used from CrickiKaze, didn't end up using
172800
$30 SuperPro SPF3560K steering rack bushing, only opened the bag
172801
$20 Siberian Bushing 2-01-641 poly front sway bar mount bushings, fits QG18/SR20 stock 20mm bar, new
172802
$75 pFb Products B15 QG18 grounding kit, upgraded wire/black sleeve/black heatshrink/copper lugs, new
$25 pFb Products B15 battery ground replacement, new
172805
$50 Nissan 54329-16A00 B13 metal strut thrust bearings, pair, new (upgrade for B15 plastic bearing)
172807
$30 Energy Suspension 7.1110G black poly motor mount inserts for SR20/QG18, new
172808
Discussion Starter #2
OEM replacement parts
$50 MAS IS380XL inner tie rods w/ Beck Arnley rack boots, new
172809
$10 Eagle BHP 9001 OEM replacement rear trailing arm bushings, new
172810
$10 Moog K201536 OEM replacement front sway bar mount bushings, fits QR25 stock 22mm bar, new
172811
$20 Rockford CV 213-24 inner CV boot kit for QG18 (also fits many older GA16 Sentras), new (this is a USA made boot, very high quality, cannot just order online, 1000x better than China made junk)
172812
Discussion Starter #3 (Edited)
The following parts are all $5 each and brand new (unless noted) but I will make deals to just get rid of them if you buy something else
Nissan OEM QG18 vacuum hose diagram underhood label 22304-4Z800
Nissan OEM A/C label 27090-4Z000
Nissan OEM fan warning label 21599-ZT50A
172814
Mevotech MK9543 sway bar link
172815
Nissan OEM exhaust gasket 20691-51E01, goes between primary cat and b-pipe on QG18
172822
Delphi fuel pump assembly retaining ring and o-ring
172817
OEM Nissan/TYC tail lamp wire harness (one each, TYC is new, Nissan used off my car)
172818
OEM Nissan trans output seals for QG18 auto 38342-8E000 (have 2, sold individually)
172820
If the rear trailing arm bushings fit the space v rear beam,
I'll take them, the battery tie down & exhaust gasket.
I need the output shaft seals but I'll cross check the part number and see if they fit the spec trans.
Edit: nvm, to early for me to read apparently lol 🤷‍♂️
Bump, if you want a large amount of parts I can be a lot more flexible on price since I can cut shipping costs (everything is priced like it would ship by itself). Let's make a deal!
1 - 8 of 8 Posts
