1 - 16 of 16 Posts
I’m in urgent need of engine harness and can not seem to find one. What Sentra or compatible car could I use. I have an 04 Sentra ser spec v
Do you need nats or non nats?
You need either a 04 or 05 spec v harness
What is nats
Nissan anti theft system. Do you have a red blinking light on top of your dash?
Oh no I do not. I’ve been to junk yard and seen the ECU plugs but I have manual transmission and not sure if all lines ups.
All spec v are manual. What's wrong with your harness
Either the harness is shorted I’m no that mechanical inclined to check that but I have replaced vvt solenoid 3 times and I’m getting the same code over and over again so I’ve narrowed down to harness or ECU
So that makes it an 04 without nats. So an 05 using an ECU with "GT" on it would be compatible. That's about it unfortunately. There's only 2 different harnesses for the spec v trim, either nats or non. You can't use 06 harnesses either because of the wideband sensor that they incorporated for 06's.
1 - 16 of 16 Posts
