So driving the other day i decided to give my car a run throught he gears and it happend. i
i pulled over and i heard a strange noise. it sounds like its knocking from the left right side of the motor so i shut it off.
it had been making strange noises allready as im sure it sucked up a bolt or 2 from the intake manifold
because secondaries no longer open. also it had been smoking at high rpm.
so heres my question. Should i pull the motor and rebuild or am i better off buying a block off someone ?
I do not plan to build it. if i were to rebuild it would be oem drop in and go.
me and a buddy will be doing all the work so no labor charges. what can i expect when i open the block?
Any advice is appreciated.
