1 - 20 of 61 Posts
i've been having this problem for about 2 months now, and it hasnt gotten worse or better. It doesnt smoke when i'm at idle, it doesnt smoke when i'm at partial throttle, it doesnt smoke when i'm crusing. It ONLY throws out a puff of blue smoke everytime i switch into gears while i'm in boost 6psi or higher. I'm not sure if it's the type of bov i have, (apexi dual chamber) thats making it have rich conditions but when i shift i keep an eye on my afr and it goes from normal afr crusing at 14.9 then i punch the gas till it builds boost then i switch the gears and as soon as i let go and punch it to the next gear the afr goes to 11.0 . AFR drops alot in between shifts, then goes back to normal.
another example is when i'm tuning the car it's at 11.5 @WOT but when i do a quick shift to the next gear it drops to low 10's then back to 11.5.
also i've checked my oil and its missing sometimes like if the blue smoke is oil or something.
blue = oil
u been letting the car cool down after drives and warm up before boosting it??
yea i let it cool down for about 2mins but it only throws the smoke in between shift at higher boost, it doesnt happen when i'm driving normal.
yea seems like some oil is getting thru the turbo seals at certain rpms thats why at 6psi u dont see any smoke. but when the turbo hits higher rpms u get a lil smoke... thats what i think, but i could be wrong :)
is that turbo ball bearing?
u got a point there.
yea it's ball bearing.
oh man lol, bearings could be going too... thats why i stay away from those things. theyre great give a quick spool and everything BUT u gotta be more careful than a regular turbo. in other words, like cooling time, u gotta let it cool more because of the bearings.
u have oil cooled or oil and water? im assuming just oil
Discussion Starter · #7 ·
well i guess the seals are going then cuz it hasnt gotten worse or better, it's consistant lol. i'll let it cool down for 3mins this time after shut down.
just oil.
just oil.
dont forget the kind of abuse that turbo seen before u got it.
prolly still got warranty on the turbo.
if i ever went ball bearing id do oil and water, its just my personal preferance.
Discussion Starter · #9 ·
so u dont think it's the bov? cuz i've seen reviews of that kind of bov causing rich conditions when shifting gears, but then again wut color would the smoke be if it was rich blackish right. I just dont like how the afr drops per shift.
yea if it was running rich, the smoke would be black, antifreeze is white and oil is blue... i mean it could be something else but i think u seemed to get the motor right the last time around..
well you were running rich that night after the SI meet but i didnt notice any blue smoke
hell yea and my windows were up thats how i knew you were running rich smelt like gas fumes
1 - 20 of 61 Posts
