1 - 8 of 8 Posts
Ive been reading around and found you can use a blue top optima battery instead of a yellow top. Anyone running a blue top and know what specific battery size you got? If you have a yellow top what is your as well, has to be similar.
Why do you want a marine battery application? Blue tops are for water applications.
Just an fyi, any marine battery works. I use "2" Deka Marine Master batteries(either 24m5 or 24m6, cant remember). 1 under the hood and 1 in the trunk. I run the amps to the trunk battery.
People have good and bad experiences with Optima. If you want a better agm battery, get an XS Power. They also sell the xs 555 and xs 556 to give extra terminals, but only work on certain batteries.
Good luck!
Now, if you want blue for a color scheme, forget everything I just said lol
Discussion Starter · #7 ·
Ugh your right, Ive been thinking about getting an XS, probably the D1200. Just havent heard much about them except that they're car audio batteries, but I wonder about reliability
1 - 8 of 8 Posts
