1 - 4 of 4 Posts
Anyone have a similar problem where the rear brake rotors 12.3" on the right side passenger is making a squeaking noise? It sounds like metal against metal scraping. I thought it was coming from the caliper shims but not too sure anymore.
did you follow the break in procedure for the pads? assuming you got hawks or ebcs
yea I did. I don't think it's the pads... I took out the caliper and rotated the rotor and it sounded like the shim was hitting the rotor on certain spots, so I bent the inner tab on the shim in and that helped until I put the wheel back on.
1 - 4 of 4 Posts
