1 - 7 of 7 Posts
Going to be painting my car soon. How do I remove the front bumper on my car.
Discussion Starter #2
Looking for info on front and rear bumber removal, and sideskirt and door molding removal. Please help.
front bumper is really easy remove fender liner and i beleive its a 10mm bolt unsure but either way remove the bolt and the bumper will hang freely on the sides
then just remove radiator support tabs and grille and you are set
Rear bumper is much the same, 2 bolts each side and the 2 plastic push pins ya see when ya open the trunk. side skirts are easy too, there's screws in the wheel wells(3 up front 1 in back) and 7 bolts on the bottom tabs. Remove those and gently pull down and out/away from car. The little plastic clips should just pull right out.
1 - 7 of 7 Posts
