1 - 12 of 12 Posts
I have an 04 Spec v with 190k, no precat, and valve cover has been replaced. I noticed it burned a lot of oil to the point I now add about a quart every 300 miles. It burns a ton during cold start with a lot a smoke out the exhaust and a lot more when you step on the gas. I also noticed that oil was puddling in the intake where the respirator tube is for the engine. Any ideas? Should I rebuild or buy a new engine?
It's not going to be from the butterfly screws Zeno.
Start with the PCV valve Op, if that is worn out if will cause a little more oil consumption. Try a different weight oil as well.
Unfortunately these motors are known for burning oil and if you want a idea for a next move you should fo a comp check and a leak down.
When was the last time you checked your coolant?
Why couldn't it be the screws if one or more got loose and scoured the engine walls? I know that causes massive oil consumption, almost always. Unless it's making purely white smoke then maybe headgasket? I assume OP would have seen the milk oil tho.
Not saying it couldn't be the pvc, that would also be a good place to start. But a little bit of oil there in your intake tube is normal which is why people use catch cans.
Nope all piston ring wear and tear.
That involves lots-o-work. If the cyl walls are scored it needs to be bored 20 over. That requires engine removal and a machine shop. Block disassembly for rings is a huge risk when there is no guarantee. Get a block for $800 and call it a day
Problem is, how do you know youre getting a decent engine tho?
At this day and age, I always recommend rebuilding it. At least then you know whats going into it.
I guess it is a more advanced way of working on a daily, or a beater, but this motor is simple enough to learn on.
How about buy another motor, slam it in, and rebuild the block you got sitting around?
yeah I would Check the pcv valve first it’s only a couple of bucks to replace but it might honestly be the rings cause I’m burning oil as well and form all that I did it just point to the fact that it’s must be the rings yet again my car starts for one time but it wont turn back on unless I let it sit for a while
burning oil is normal , anyone who says otherwise is a piece of shit liar. My spec burns about 3or 4 qrts every 3k.
I do run race fuel, and i drive it like i robbed a bank. personally I noticed more oil comsumption after i did my BSR Kit, and Seafoam.
Burning THAT much oil is not normal bruh...
Granted you beat on the bitch, so you set that expectation, not all of us build a beater, some want gas mileage, and minimal maintenance, and that is okay too.
1 - 12 of 12 Posts
