1 - 7 of 7 Posts
So I have 08 sentra commuter, and it give me grief pretty frequently starting up....im fairly certain its the clutch pedal sensor. I tried jumping and bypassing the "switch" that is pressed when the pedal isn't pressed....but the issue reamined...so im guessing that wasn't the sensor that I needed to bypass....where should I look to find the right sensor? Is it on the trans somewhere?
Sent from my SM-N975U using Tapatalk
That was the wrong one, that one was for the cruise control. The actual clutch switch is behind the clutch pedal on a bracket.
Behind the pedal, as in towards the firewall? Down low (towards pad?) Or up high towards the cruise switch?
Firewall, look at the arc of travel and you should find it unless it's higher up on the fire wall.
I have 2 switches for my clutch.
Yeah, theres nothing down low..theres just a metal plate where the pdeal hits...maybe theres one up higher...ill have to flip uoside down and get my head under there to look
Push the seat all the way back, lean the seat all the way back, lay in seat upside down, wear a headlamp, you will see all.
Only beginners lay the seat back...
Reactions: Kazspec04
1 - 7 of 7 Posts
