1 - 20 of 21 Posts
are u supposed to hear the turbo at idle? i have the turbonetics setup t3 t4 ball bearing. i noticed its misfiring so i am waiting on the new coilpacks ,hopefully that fixes tghe problem. its backfiring like crazy too. when i drive i notice it goin into boost fairly easy but it lacks a lot of power . maybe its all correlated
What are you using to tune with?
EDIT: and no, you shouldnt hear it at idle.
You are not going to hear the turbo until you build boost, which only happens under some sort of open throttle (accelerating exhaust gases spinning the turbine and such). It is just going to flow through at idle, since there is not enough velocity from the exhaust gas to spin the turbine.
I am waiting on the coil packs ...... car is misfirin like crazy .that's
Why I was wondering if its all correlated .
you might hear it at mild throttle if you're running an open downpipe that's recirculated. oter than that, no you won't hear it at idle.
hell my turbo doesn't even spin at idle.
You gotta have a small ass turbo to hear it at idle with smaller engines. That's why I laugh when hondas pull up and you can hear them spooling
Discussion Starter #16
I had some people ask me why my Turbo didn't make
A noise at idle ... that's why I posted this . I just had to
Make sure.
Cause you have a big boy car and a big boy turbo, with big boy 4cyl displacemaent and big boy torque. :cool: . What are the AR's on your turbo?
1 - 20 of 21 Posts
