Hey guys I have a 03 Ser spec V with 276,000 miles stock motor and a issue when the car is at a stop or if I’m coasting at neutral it dies. The car has no codes and was wondering if anybody has any insight. Thanks
Administrator
Throttle body might be going out, check to see if you have pending/soft codes. Take the time to do a throttle relearn as well.
Reactions: kvngopats
That shouldnt do much its usually only emissions related. I would also bet that the throttle body is gummed up in the bore. You have to do the idle relearn tho if you ever mess with the tb
Reactions: orangebeard
