1)Yes it pulls right out. The dowel pins might give it some resistance but it should just come up. Make sure you don't lose that o ring that sits between the head and timing cover just beside the part where you have to make a circle rtv.
2)Yea water can come in thru the headgasket and the pistons are just simply pushing the water up.
3)Resurface the head and have the valve seals replaced at least. You can always get it rechecked and get a valve job if you want to, but in most cases no.
4)They will resurface it to specs (assuming it's a reputable machine shop) which means they will only take off what's necessary which is sometimes just a few thousandths of an inch (0.0001"). The bolts will fit fine.
