can we still use the "07" kit..like the valve cover gasket, intake manifold gasket, etc? What about a GEN 2 (07+) Head?The gen2 headgasket is better and does replace the first gen gasket. There is an oil passage in the older gasket that the newer version does not have. I used a large drill bit to open that passage up. Others have just left the passage closed, I believe.
Gotcha...would it be wiser to acquire another head to have machined and finished to swap...this write up just showed the head gasket being the culprit...I would hate to do all this work and have to take it back off again.Only the headgasket will fit the first gen QR. The head itself and valve cover are different. Not sure about the IM gasket.
I'm only pushing 8lbs, nothing too radical. I was going to go with the 07 B16 Headgasket from Beck/Arnley (0352148). It's my DD, so I'm too keen on having really flashy parts until this becomes my "weekend" car where I can afford to leave it sit for ever. It's my DD, I do have a friend loaning me their van this weekend for a few weeks, so I was going to take the head to my local machine shop to have it checked along with the valves.Norberto, if you can afford the car to be down, I would just reuse the head (have it checked out first and change the valve stem seals at a minimum) and use either an AJUSA or the Cometic that 2J is selling since you're boosted. You could get away by just using the 02-06 HG if you already have one, but if not you could use the 07+.
I went ahead and ordered the AJUSA headgasket (10145500), for under $60 shipped via CarId, not too badYou dont want to do this job more than once, I would just get a good head gasket now and be done with it. I got my ajusa on ebay for $85 shipped to canada and it makes oem gaskets look like tinfoil imo. Even if the 2nd gen gaskets are better than the 1st gen they were still never intended to see boost no matter what the psi.
One more tip, dont let your dunken buddy flip your head over and scatter the lifter buckets all over the floor either. Setting valve lash from scratch sucks balls.
So essentially, DONT turn the head upside down correct? I went ahead and ordered some ARP head studs in an effort to overbuild the motorYou dont want to do this job more than once, I would just get a good head gasket now and be done with it. I got my ajusa on ebay for $85 shipped to canada and it makes oem gaskets look like tinfoil imo. Even if the 2nd gen gaskets are better than the 1st gen they were still never intended to see boost no matter what the psi.
Can you reference the page number? If you look at how they want you to take off the head, it states to take off the lower oil pan, and the timing chain cover....something that is not needed honestly.It is in the fsm....the way they portray it CAN be confusing for some.
