1 - 3 of 3 Posts
So I have an 04 Spec V and I am going to try to swap my starter are there any how to forums already? Or anyone have some helping knowledge if it's a tough swap or not? TIA
Should be pretty easy honestly.
Disconnect battery. Remove your air intake so it's not in the way. Unplug starter. Take out a couple bolts. Put new starter in. Put bolts back. Plug back up. Re connect battery. Enjoy ;)
Takes about 10 minutes literally (my first spec eats starters). You only have to remove three bolts. The plug, and then the bolted in wire coming from the battery (disconnect the + from battery first) and two 17mm bolts(think they are 17, maybe 19mm) pull out and then reverse.
1 - 3 of 3 Posts
