Hey guys, I have a little problem, there's a clunking noise that comes from the front of the car that started Yesterday. I don't know what it is. Even if I drive straight it clunks, any little movement I hear it, if I go over a speed bump SLOW AS HELL, I still here it, freaking me out. Thanks!
Should have someone drive your car with the hood off and see if you can replicate the clunk.
To start, check your motor mounts, see if any are broken.
Look at your suspension.
Narrow down what part of the car it's coming from.
while hood is up either you or someone els e watch the engine for movement, pull the ebrake, put it into 1st gear barely let out the clutch , if mounts are bad there will be alittle or alot of movement more so than the car that is
7 year old thread...
