1 - 20 of 95 Posts
Fuel pump primes
Just put in new cam / crank sensors
And put in a new battery today
Car wouldn't start this morning. Drove it all day Saturday no problem
Now it just cranks all day. Fuel pump is fairly new and primes as normal
Any thoughts. Plugs don't look fouled but I swapped them anyway
Discussion Starter #2
Bump. Just swapped my fuel pump with my roomates 04
Also just checked all fuses
Nothing different
I'm not sure if my injectors are firing at thia point.
Nothing different
does it feel like its cranking weak??
Slightly
Here's an update. Ecm relay stopped turning on. I swapped it with another but no luck
My safc also stopped. Are there fuses for thw ecu. Could I have possibly fried one
Ahh... Way above my level buddy
Ecm gets power
Replaced relay
Everything turns on but no spark when cranking. I'm throwing a cam sensor code that I thibk is from a corroded connector. I have re wired it but the code still keepancoming up along with p1111
Turn the key to the "on" position, see if you have power coming out of the cam sensor connector on the red/green wire. Check if you have power on the red wire on the CVTC solenoid. The only thing that is common to the cam sensor and CVTC solenoid is the ECM relay and fuse#36 under the hood. Turn the key off, check continuity to ground on the Cam sensor plug (black). Check continuity from the green wire (ivt solenoid) to pin #107 on the ecu.
The only thing that bothers me is that you're saying that the ECU has power. If it does, then that fuse#36 should work because that's what's giving the ECM relay power to turn on the power for the ECU.
Yeah the eccs fuse
I popped it yesterday and put in a new one
Currently my cam sensor has a homemade harness so I'm teying to figure out if the wires are correct
Black wire
Red wire
Red with green stripe. Not sure where they correapond to the sensor
Awesome I will correct this and update
Discussion Starter #11
Forward in realtion to the car?
Timing chain stretched? Put #1 on tdc, pull the cam sensor out and look at the marks on the camshaft. They should be flat. Seen this happen a few times.
Discussion Starter #14
Cam sensor has voltage
Vtc does not
About to set at tdc
Discussion Starter #15
Timing is good
Also I'm getting no rpm reading while cranking. Is this normal
Discussion Starter #16
Just tested the vtc solenoid. Seems tonwork with 12v. Only code right now is p1111. I don't see that making a no start
So the cam sensor is now ok? So you confirmed no spark right? Check and see if you have power to the ignition coils. Also check while somebody is cranking to see if you have voltage out of the ignition signal from the ECU.
Discussion Starter #18
Will ignition coils get power witg key on or only while cranking
No cranking rpm indicates a crank sensor. Do you have access to a scanner? Id ike to know what it sees for rpm while cranking.
Im assuming u cleared the codes after fixing wiring. And it is still throwing that code...
Basics. Fuel , spark, air....
Test fuel pressure koeo. See if within spec.
If yes look at injectors.
Spark...tech you can rig up a jig to test this.. But a low amp current probe is best/easiest.
If you have spark...and plugs are good...check ...you do have gas right?
Normally id say check maf...then timing. Let me know what you find
Compression test comming up...lol
Hopefully not
Discussion Starter #20
I don't seem to get any voltage read at all from the coil
I used a dmm lead to probe.
1 - 20 of 95 Posts
