41 - 60 of 88 Posts
Discussion Starter #41
quick pull to mid 4th gear. @ 1:06
<iframe width="420" height="315" src="https://www.youtube.com/embed/W7UABf3eMCM" frameborder="0" allowfullscreen></iframe>
Are you not afraid that something will be sucked up into that thing and kill your turbo?
or the dryer duct will be sucked into the turbo? I would put a decent screen on the turbo inlet, if nothing else. BUT, if it works!! You get the BDSO of the Year award!
Wait... That's a thing?
I don't think we should challenge the true BDSO? Those fuccers would do some fucced up shyt.....lol...lol
Daveo is a silent baller.
you should see some of the stuff they post on facebook, lol. its a badge of honor there
That's one of the reasons why I don't go onto face book.
Where there are younglings, there are the MOST STUPID, IDIOTIC SHYT you'll ever see.
Discussion Starter #49
great idea for CAI
do you think that will sustain turbo vacuum and not collapse?
I put the intake tube back on and screen at the end, then rerouted the duct to it.
Discussion Starter #50
Discussion Starter #51 (Edited)
it's thicker tin, not the aluminum paper stuff, I use high quality parts even when plumbing or hvac, ha... I want to see if it would make a difference during mid day heat. it works on break ducts and I don't want to hack a turbo hood scoop in.
Discussion Starter #52
More sentra fun. I sprayed the shifter linkage last week cause it was getting squeaky, this is the result a week later on the way to school.
<iframe width="420" height="315" src="https://www.youtube.com/embed/2FnsCTHp0BA" frameborder="0" allowfullscreen></iframe>
Discussion Starter #54
It snapped the previous owners cables. I was going to take it off but never got around to it.
Discussion Starter #55 (Edited)
0828162059-00.jpg 0828162059-01.jpg 0828162059-02.jpg 0828162059-03.jpg 0828162100-01.jpg 0828162109-00.jpg 0828162112-01.jpg 0828162115-01.jpg
I started testing for boost leaks today, found one on top of the bov, so I took the bov apart, and put some pipe dope on the threads after I figured out how it worked.
there where also two on the extra fitting ports on my boost controller, so that was cleaned up n doped. I'll do another test in the morning.
Discussion Starter #56
Switched it up after the boost leak test.
Discussion Starter #57
Discussion Starter #58
So like, I got the car running well, had to retune it after the boost leak test, that was interesting, oil blew everywhere in the motor from the test, I cleaned the plugs and drove it ti clean it out, the boost is pulling very hard now, now to focus on the wheel bearing or cv axle. something is dying there, possibly both. still loving the battery position change though..
41 - 60 of 88 Posts
