1 - 8 of 8 Posts
Read there's a control box for the dome light and I'm having issues with mines, works when u switch it on manually but not when the doors are open, the door symbol come on when each door is open but still no light
burned out bulb? there is a switch lever on the rear side of the light, if I remember correctly, it has to be in the proper position for the door switches to work, it should be a 3 position switch, off, on, and door
Ty, I got leds in but it jus stopped working, I even changed the whole assembly and the dome still don't work
No open door turns the light on but it shows an open door on the cluster
1 - 8 of 8 Posts
