I have an 06 spec v that needs a new door latch on the driver's side. I have the panel out and was wondering how to get the actuator out. Everything is disconnected except the rod that connects to the door handle. Any advice would be appreciated
There should be a plastic clip that holds the rod on, flip it to release the lock or something like that...
Yes and no, there is also a bolt in there and you can get to it from the inside as well as the outside. If I have my old handle still I will post it.
Everything is disassembled except for the one rod going up to the handle,which I think is last thing I need to take off.
You just need tiny hands to work in there. TBH once you have all the clips and the bolts holding it off it should just pop out. You just need to snake it out of the door.
