1 - 5 of 5 Posts
Hi all, real quick...
For the bolts that hold that Brembo Calipers to the knuckle assembly:
Does it go Bolt: lock washer: flat shim washer: and install all into back of knuckle?
OR
Bolt: lock washer: install into back of knuckle and then the thin 'shim' type washer in between the knuckle and caliper?
Putting my car back together after a few months on stilts and now cannot recall. Not really sure it matters too much either?!
:confused::thinking:
I shouldnt matter. I dont think you even need the larger flat washer.
Thanks for the replies!
MoltenNismo: Yep...still got er-- I remember you and the meet it was one of the better ones (a decade ago!!)!
All four bolts had the thin flat washers-- I put them in between the Caliper and the knuckle-- since the caliper is painted all around, I assume the washer was to save the paint? Either way, don't think they're too important.
I was wondering what those were used for myself when i had my 05 Brembo Conversion....never used them. just used what was off the old calipers...no issues
1 - 5 of 5 Posts
