1 - 10 of 10 Posts
Hi all,
I have a JDM Nissan Sentra 1.8l. I want to make some changes, like header, new cold air intake, new exhaust catback system 3" diameter and a T25 turbo at 7psi. i would like to know if my ecu can manage this extra air flow without modification? If i will have to modify the ecu, do you know somebody or shop that can do it for me.
Regards.
Contact Uprev and see if they can help you out. They currently do not reflash the QG ecu, but no one has stepped up to try it out.
http://uprev.com/
What makes your B15 JDM? They were all assembled in Mexico.
lulz @ JDMB15 xD xD wish i could have a JDM 1.8 sadly mine is only a MDM/USDM 1.8
Discussion Starter · #4 ·
I think it's a JDM because the ecu is not obd-2 compatible. I have an Actron scanner for obd-2 and it cannot read the codes.
here another question. Dou you think that I can use the ecu of the sentra se-r 2.5 on mine. I mean by that, is there a way after some modifications to use the sentra ser 2.5 on my QG18?
Either way it is not JDM, no such thing exists. And just a heads up, a cold air intake and header will not be compatible with a turbo system.
Do you have codes currently? They can easily be accessed without a scanner.
1 - 10 of 10 Posts
